Smartest GW500/BT1500 install in a Boxter S 2007 w. PCM 2.1
Dension Gateway 300, Dension Gateway 500, Dension ice>Link One, Dension Gateway Five and Dension Gateway Lite adapters for iPod / iPhone, MP3 players and USB sticks to your car multimedia system.
Postby Stuttgart » 14 Sep 2012, 22:46
Like the subject says: The absolute most clever & hidden install with no extension cables needed or modifications to the interior. Over to my questions:
1) I have absolute latest PCM 4.0 version (I guess), PCM Actual: 05395BD1/4505 & PCM System Software: 05462AD1/4605 without the physical CDC (CD Changer) installed but my PCM 2.1 is prepared for CDC, Porsche order code 689. Do I regardless this need to re-activate the CDC function for the Dension kit or will It work fine as is today?
2a) How/where to put the RCA & external in box with the master power switch box (I want everything 100% hidden, gloove box?)?
2b) How/where to put the iPhone USB connector? I dont want to put It visible in the interior either & I will NOT use the iPhone stand & mostly go for Bluetooth for both music streaming & phone calls If It's not to slow (..or is It?)
2c) Is the smartest to place to put all Dension boxes: Behind the PCM 2.1 unit instead of beside the nav-DVD in the front trunk?
2d) Where to get the power from If placing It behind PCM 2.1, a permanent bus or? Will the Dension units have a 100% auto shut off so It doesnt drain my batteri If standing for a longer time?
2e) Best placement of the BT mic & I guess using the defualt handsfree Porsche telephone mic was to complicated?
A guy from this YouTube clip: http://youtu.be/l81hL9oxns8 did install the Dension kit in the front trunk of a 997 but later he replied like this instead that is probably the smartest after all:
"I would recommend placing the connectors in the glove box. I did an installation like this in a Cayenne and it turned out very well (it was fairly easy too). I pulled the PCM out and away from the dash and mounted the Dension unit behind it. I then ran the connectors into the glove box through a hole I had to drill in the back of the glove box. Aside from this slight mod, all the cables fit behind panels for a clean look. I also ran the microphone cable behind the driver side foot well panels and up the A pillar. Then behind that A pillar panel and ultimately mounted the microphone on the panel with the interior lights/garage door opener. Also, fairly easy to hide the cable."
Finally, pictures would be extremely helpful also beside your written answers.
Best Regards & thanks in advance from Helsingborg, Sweden,
My car: http://q-force.se/box.html
Stuttgart
Car: Porsche 987S PCM2.1
Return to Dension iPod/iPhone / USB / Bluetooth Adapters
