CS9100/CS9200 navigation boxes, navigation systems for Lexus, Toyota, Mazda, Subaru, BMW, Audi, VW, Mercedes-Benz and othe car brands.
by FISHERMAN » 29 Apr 2014, 14:59
Dear, friends
I see that you have annouced a new model CS9320. Is this model compatible with my ALPINE IVA D310 monitor?
I am using this monitor and touch capabilities with a CS9100 for a very long time and i would like to upgrade.
Do i need another set of cables or i can just unplug CS9100 and plug CS9320.
Thanks in advance
FISHERMAN
- Car: Renault Clio 3 '05
by Chortenia » 30 Apr 2014, 11:12
CS9320 has the same protocols as CS9200/9900, so it should work with ALPINE IVA D310.
You can find ALPINE compatibility list
here.
- CarSolutions Team
- Car: Chery Kimo
by Tagchen » 14 May 2014, 10:18
I will use the CS9320 on Kenwood KVT-827(DVD). My Question, how must connect the touchpanel with CS9320?
Connect the Kenwood with the cable KEN-RGB1 same as CS9200??
Tagchen
- Car: Passat 3B6
by Chortenia » 16 May 2014, 11:04
Yes, connect it with the
Kenwood cable and select Kenwood protocol in CS9320 settings.
- CarSolutions Team
- Car: Chery Kimo
by rolchg » 26 Sep 2014, 00:21
What is the minimal cable connection to perform
test out of a car?
Is it enough to connect:
1. yellow (BATT+) (permanent +12V)
2. red (CAR_ACC_IN): +12V after switch (ON/OFF)
3. black (GND): ground (-12V)
4. CVBS to monitor
5. GPS antena
6. USB mouse
or additional connections to "data" cable are necessary?
rolchg
- Car: Audi A8
Return to Сar Navigation/GPS
Users browsing this forum: No registered users and 43 guests
