Mirror link .+ S6 + ...GPS ?
CS9100/CS9200 navigation boxes, navigation systems for Lexus, Toyota, Mazda, Subaru, BMW, Audi, VW, Mercedes-Benz and othe car brands.
Postby picolo » 19 Apr 2018, 20:32
Hello
(sorry for my English)
I bought a video interface in 2017, I use it for the backup camera, it works very well, now I would like to use the GPS of my phone
(S6 Samsung) mirror to have a GPS on the screen of my MMI 3 G Basic.
so I have to go through, by my video interface, my question is .....
Is that possible ? and what material do I need?
thank you for your attention.
picolo
Car: Audi A6 C6
Re: Mirror link .+ S6 + ...GPS ?
Postby Yuretz » 20 Apr 2018, 11:22
You will need a mirroring adapter like this one https://car-solutions.com/en/smartphone ... utputs.php .
Postby picolo » 20 Apr 2018, 12:40
Hello
sorry, I did not see your answer.
ok, but .... what's the difference with this other object ?
the most compatible with my video interface? .... (audio ? )
https://car-solutions.com/en/smartphone ... output.php
my video interface.
https://car-solutions.com/en/video-inte ... th-pas.php
picolo
Car: Audi A6 C6
Postby Yuretz » 20 Apr 2018, 13:41
The difference is in connection cables. The first one has HDMI and RCA and the second - RGB and RCA. Both will fit your video interface. The one with RGB displays the picture better via RGB but your monitor should support 800x480 resolution.
The sound is coming via RCA in both cases.
Note! A video interface doesn't transmit sound to the OEM audio system. It can only switch between connected sound sources. You should connect the linear output of the interface (AV OUT cable) to the AUX input of your car.
Postby picolo » 21 Apr 2018, 01:59
thank you Yuretz
picolo
Car: Audi A6 C6
Return to Сar Navigation/GPS
