Touch screen dimensions (tolerance)
Posted: 11 Nov 2012, 20:00
hi there.
I just realized that for 45 buck I can get touch screen for my Accord 2003. That car has something like a touch screen but it is actually two rows of sensors X and Y on the left and on the bottom of the screen. And certain buttons on the navi can work even if you wont touch the screen. Anyway. I'm guessing sticking something that is less than 1mm thick on that will not affect that functionality. Am I right?
My real question is:
Will 7inch touch screen (153mm/85mm wroking area) be large enough for my factory Navi screen? My visible area on the screen is about 5mm wider and approx. 4mm higher - 158mm . 89mm. Will it be safe to use that touch screen? I mean, I read that outside area (inactive) is kinda fragile and I don't want to break it, simple as that. 2mm around the screen is not a lot but...
And actually with the finger it's not possible to touch that area. I'm not gonna use any stylus so maybe that screen will do the job? What you thing experts?
Spasiba
Spasiba
