Audi a6 2009 mmi 3g and camera
Postby Pierrott » 23 Oct 2016, 13:15
I would like to plug a wifi camera.
Is it possible with thisinterface ? It says a6 2011 only but my car has exactly the same mmi 3g high as 2011 car?
http://car-solutions.com/en/car-video-i ... system.php
What about this one ?
http://car-solutions.com/en/camera-adap ... elines.php
If i have a front camera how would it be switch it on? Manually, with mmi buttons?
Can i use both gps and front camera ?
Pierrott
Car: A6 2009
Re: Audi a6 2009 mmi 3g and camera
Postby Yuretz » 24 Oct 2016, 11:56
Yes, it's possible to connect any aftermarket NTSC camera via RCA.
It will fit if your is equipped with 7'' high resolution (800x480) screen.
mmi button or mode swith button.
Yes.
Postby Pierrott » 24 Oct 2016, 20:55
Thanks for your answer. I have an Audi A6 C6 2009 facelift with MMI 3G & HDD (I think 7" screen).
Is there any complete user documentation for this product ?
What are the main differences with this product except HDMI inputs ?
http://car-solutions.com/en/video-inter ... elines.php
I only want to use 2 camera (one front and one rear).
I want to switch between the 2 camera ONLY with OEM MMI buttons (no physical switch to select inputs) and enable them when I want (especially the front camera).
What do you advice me ?
Thank you very much.
Pierrott
Car: A6 2009
Postby Yuretz » 25 Oct 2016, 13:00
The manual is under the product description .
You may use OEM buttons on the MMI controller and steering wheel to switch inputs.
You may try this adapter http://car-solutions.com/en/camera-adap ... elines.php
if your car is equipped with the high resolution screen 800x480 .
Postby Pierrott » 25 Oct 2016, 13:29
Last question, how to be sure to have the screen 800x480 and the LVDS plug (I understood this plug is the one necessary to use OEM button) ?
The MMI has a DVD player and an internal HDD.
Pierrott
Car: A6 2009
Postby Pierrott » 25 Oct 2016, 15:54
I answered to my own question as I looked to wikipedia
https://en.wikipedia.org/wiki/Multi_Media_Interface
MMI with SD card, HDD and DVD video player are MMI 3G High with 7-inch TFT color display VGA resolution (800*480).
Pierrott
Car: A6 2009
Postby Pierrott » 26 Oct 2016, 09:39
An other quick question, it seems to have available
iw04A and iw04A-N.
I ordered this product
I specified that I have a MMI 3G with A6 C6 car.
Which one will I receive, iw04a or iw04a-N ?
Pierrott
Car: A6 2009
Postby Yuretz » 26 Oct 2016, 13:57
You should contact our sales department http://car-solutions.com/en/information/contacts.html about this.
