difficulty to connections
Hello everyone
really not very clear the documentation, I have a lot of difficulty to understand.
I often make electrical connections, but the documentation is not clear
I hope you can help me.
I bought this interface for my A6 4F MMI 3g Basic
https://car-solutions.com/en/video-inte ... th-pas.php
+ 12 / gnd power supply, ok, but the questions remain!
on the image that I present to you, all the questions are present in image.
1) cam rear , I installed it, I plugged it in before receiving the interface, this camera is powered by 12v as the vehicle goes into reverse.
question, plugged the connector "R-CAM"? or not ?
2) The interface wires, yellow, purple, gray and white, they plug or ?
what connection in the car ?
3) Cabling "CAN" ok, I use "HS" if no good..., "LS"
I do not cut the original wires, I connect them "green / brown (command) with green" and orange / brown (command) with green / brown
4) RGB-in connector, why ? necessary ? , wiring in the car ? or ?
the questions in pictures :
https://img15.hostingpics.net/pics/939454608.jpg
Thank you for you precious help
