Interface does not work anymore
Postby Jorgos » 04 Jul 2018, 16:35
It happened yesterday. Everything was working correctly for the whole day (and past half a year...), I parked my car and enabled handbrake, when i received error, that handbrake is broken (even though it worked), then i tried to stop engine - it does, but all dashboard items were still on (clusters, radio). I disconnected the hdmi interface and everything went back to normal - all errors dissapeared.
Today i tried to connect the interface again - it started to get really hot, and again, all devices in my car started to going crazy (even emergency lights switch started to blinking).
I disconnected CAN wires and tried to connect interface again - MMI buttons didn't work (connected with separate wire, it worked since the first day i bought it...), but i was able to switch to interface using "MODE" pin. The whole view was moved to left. because it get again very hot i disconnected it and I took it home.
Do you have any idea what happened and what can I do with the issue? Thanks for advice and support.
Jorgos
Car: Audi A6
Re: Interface does not work anymore
Postby Yuretz » 05 Jul 2018, 11:41
Errors can appear because of wrong CAN connection. Please check CAN wire connections once again https://car-solutions.com/nfs/product/8 ... manual.pdf.
Heating of the video interface is allowed.
Postby Jorgos » 05 Jul 2018, 15:00
Interface was working correclty for about 9 months with this connection, and it stopped to work 2 days ago.
I have disconnected CAN at all. I suppose, device should work normally without CAN connected, but it does not.
Jorgos
Car: Audi A6
Postby Yuretz » 05 Jul 2018, 15:21
What exactly doesn't work without CAN connection? Could you provide a short video of the issue.
Postby Jorgos » 05 Jul 2018, 17:44
I will provide video tomorrow, as soon as possible.
Jorgos
Car: Audi A6
Postby Jorgos » 09 Jul 2018, 12:39
Forgive me late answer, I had many things to do :)
1) Can is connected, I am not able to power on my car at all (every single car device shows error on CAN - the wiring was not changed since i bought the device and it was working correctly). Please note the emergency lights switch blinking.
https://youtu.be/qwBCnswNdo0
2) Can is disconnected (I took off the wires from the plug). Car works 100% perfect, but the interface does not communicate with the MMI controller (which is connected with additional cable, so even with CAN disconnected it should work). I switched to HDMI using tweezers (i know, this is unprofessional, but i needed it just to record the video). As you can see, it switched, and showed the splash screen. I had no input connected, but if i connect it would be the same - view is moved to the left.
https://youtu.be/tV6wFu_oo-M
Jorgos
Car: Audi A6
Postby Yuretz » 09 Jul 2018, 16:37
1. Check the CAN connection once again. OEM buttons won't work without such connection. If CAN-High and CAN-Low are mixed up some errors may appear.
2. Try different DIP switch positions from DIP #6 to #10 . Manual https://car-solutions.com/nfs/product/8 ... manual.pdf , page 18. Shifted picture and CAN errors may be cause of wrong DIP settings.
Postby Jorgos » 12 Jul 2018, 12:42
Can you advice which to choose? I have Audi a6 c6 from 2010. And my DIP switches are set to
6 OFF
7 OFF
8 ON
9 ON
10 OFF
as in the manual. SHould i change it to different option? Could it change itself during work?
Jorgos
Car: Audi A6
Postby Yuretz » 12 Jul 2018, 14:28
Jorgos wrote:Can you advice which to choose? I have Audi a6 c6 from 2010. And my DIP switches are set to
6 OFF
7 OFF
8 ON
9 ON
10 OFF
Try different positions. This won't hurt the video interface or anything else. Video interface should be powered off while changing DIP switch positions.
Postby Jorgos » 16 Jul 2018, 12:46
I tried almost all options... I am giving up my hope... So i just lost 220 ;/
Jorgos
Car: Audi A6
Postby Yuretz » 16 Jul 2018, 13:43
Jorgos wrote:I tried almost all options... I am giving up my hope... So i just lost 220 ;/
You may contact our sales department https://car-solutions.com/en/information/contacts.html to send this video interface for repair.
Users browsing this forum: No registered users and 9 guests
