Video Interfaces for Audi MMI 3G 2009-2011 + RNS 850
Postby MrTinkertrain » 08 Oct 2011, 13:28
All video interfaces for Audi 09 5th and 6th versions (iD:816514) , have small malfunction if working with additionally installed (aftermarket) camera. In other words, if OEM rear view camera is not installed in the car and aftermarket camera is connected with the aid of this interface then there is about 3-4 seconds time delay in rear view camera activation. This issue can be solved only by video interface reflashing.There is no other way to solve this problem. Video interfaces can be re-flashed by our engineers, only!
How to determine whether your interface is reflashed (check photo below):
Sticker en-circled in red shows that the device has new firmware version.
Text underlined with the red line - means firmware version.
Each video interface has three stickers with this information and one sticker can be found on the box.
The same refers to other video interfaces, if you see such sticker - it has already been reflashed!
MrTinkertrain
Administrator
