2005 SLK r171 Problem
Posted: 26 Jul 2015, 07:11
I have installed the video interface (Model RGB - HE- STD - V5) and have been able to mirror my mobile phone on my head unit successfully. However, I am experiencing a few problems.
1) The video interface blows a fuse after a few minutes of use. I have tried changing the ground wire to a different point in the car but this did not help. Any ideas?
2) My backup camera will not be displayed. I know I have the camera hooked up correctly because I can plug it into a small TV set and the picture shows on the TV when the car is in reverse. The second light on the video interface unit does not come on when the camera is plugged into the interface and no picture is seen. The #7 DIP switch is in the ON position. I see that the Power Cable for the interface has a gray wire that the manual says is for the backup camera. Does this wire need to be used for my camera to work with the interface?
3) The manual does not specifically state that soldering the gray wire to the NAV select key is an option for the r171. Can the R171 use the NAV button?
4) My car does not seem to be able to use the RGB plug. I was hoping to take advantage of the PIP feature. If using this feature is not possible, would I be better off with the low end version of the interface?
Thank you for your time.
