2015 Land Rover Evoque
07 Nov 2014, 22:15
by gnb
Will the new interface (for capacitive touchscreen) work for the 2015 Range Rover Evoque?
Re: 2015 Land Rover Evoque
10 Nov 2014, 15:47
Yes. This
video interface fits Evoque 2015
10 Nov 2014, 20:30
by gnb
Thanks!
Can I also use this
HDMI->RGB smartphone interface with the Land Rover interface? I want to connect a PC to this interface for using the high-res 800x480 output.
12 Nov 2014, 15:58
Unfortunately, this video interface is not compatible with
this adapter.
29 Dec 2014, 21:05
by gnb
How do I use the touchscreen output from the RGB connector on the LandRover Interface? Can you give me the specification of the interface? It says the the 6th pin on the RGB connector can be used for touchscreen.
It also mentions some computer (FN900D) which can directly use this interface. Is there any more information available on this computer?
05 Jan 2015, 11:23
by Yuretz
gnb wrote:Hi,
Which inteface do you mean?
11 Mar 2015, 13:18
by threeseed
It DOES NOT work with the 2014 or 2015 Land Rover Evoque.
[*] The touch screen unit does not have the right connector
[*] The instruction manual doesn't match.
[*] The metal cover does not fit properly
I have just broken my head unit because of this video interface. Do NOT buy it if you have this car.
16 Mar 2015, 17:15
Please, provide the photos of your monitor (the general appearance and how the boards look like) since
this video interface fits all Land Rovers of 2011-2014 model years.
19 Mar 2015, 17:11
by gnb
Do you have any solution for converting HDMI to RGB? I have a PC with HDMI which I want to connect to the Land Rover interface for my Evoque.
19 Mar 2015, 18:04
Unfortunately, no
17 Apr 2015, 18:25
by gnb
I have connected the CS9320 Android box to the Land Rover interface for resistive/capacitive screen for my 2015 Land Rover Evoque. I am using the RGB input. But the display does not look good, the resolution seems to be off and I have a scrolling line on the left side of the screen. I have attached a screenshot below of what the screen looks like as well as the DIP settings on the Interface box.
http://i.imgur.com/LKnd3n3.jpghttp://i.imgur.com/Zajb0Gq.jpg
20 Apr 2015, 16:10
1. For Evoque switches 7 and 8 should be the UP position(OFF), however, you can try different positions.
2. Go to CS9320 settings-display-screen change-advanced settings, try various Panel settings for 800х480 resolution
23 Apr 2015, 22:07
by gnb
Switch 7 needs to be in the down position for the 2015 Evoque.
I tried all settings in the CS9320 for screen type and 800x480 resolution. None of the supplied resolutions work. Is there something else to try?
24 Apr 2015, 12:52
Have you tried panel FOSP and resolution 800x480 in Settings-display-screen change-advanced settings ?
