LR Evoque
LR Evoque
Postby ahoi » 29 May 2015, 02:34
Greetings
My question is about the MY16 Evoque (should essentially have the same relevant specs as the MY15);
If I install this interface
http://car-solutions.com/en/video-inter ... th-pas.php
will I be able to use the genuine functions (navi, front/rear camera, audio/phone interface etc)?
My intention is to add an additional device, but not loose any of the genuine functions.
Will it be possible to use a mhl/hdmi converter as the additional input?
Thanks & regards
ahoi
Car: evoque my16
Re: LR Evoque
Postby Yuretz » 29 May 2015, 12:57
All OEM functions will remain.
Hdmi sub-board is optional, please contact sales department for more details.
Re: LR Evoque
Postby ahoi » 29 May 2015, 22:31
Hi, thanks for the response. I will contact the sales
Is there a manual or some sort of data sheet for the board?
ahoi
Car: evoque my16
Re: LR Evoque
Postby ahoi » 30 May 2015, 01:32
I guess the HDMI board will be connected to the interface via RGB?
Is it possible to hook the capative touch screen either on the OEM board, the HDMI board or the video interface with this device? if so which one would be the advised output device?
At this point i only plan to attach the HDMI device to the video interface
http://www.customgadz.com/wp-content/do ... manual.pdf
It requires a 4pin input
ahoi
Car: evoque my16
Re: LR Evoque
Postby Chortenia » 02 Jun 2015, 16:29
Here is the manual http://car-solutions.com/nfs/product/855341/file/Land_Rover_2014_interface_manual.pdf
I guess the HDMI board will be connected to the interface via RGB? -
Yes
The box already has touch output UART TX, RX.
Capative touch screen cannot have 4 pin or it is necessary to use some kind of controller which will convert touch from UART to 4-pin.
Users browsing this forum: No registered users and 6 guests
