GVIF GFO8-v7 Interface - VGA to RGB Input
Postby dani » 22 Oct 2012, 08:00
I would like to use the Analog RGBC input (marked as for navigation system) to connect the VGA output of my laptop into the GVIF interface. The RGB cable only has 5 wires, what would the cable assignment be for this connection?
dani
Car: Range Rover Sport
Re: GVIF GFO8-v7 Interface - VGA to RGB Input
Postby Yuretz » 22 Oct 2012, 12:14
1. You need to convert VGA separate sync signal (HSync, VSync) in mixed CSync.
For this you need to compile the following schematic:
2. In the video interface settings (Factory mode) enable RGB devices with a resolution of 800x480.
3. Configure the appropriate mode in "PowerStrip" to implement the image output from CarPC to OEM display.
