Problem with the Range Rover Evoque Interface
Postby romano » 31 Oct 2012, 12:13
We have a problem with the first Range Rover interface ( 837035 ) . It looks like it doesnt support PAL. It only works on NTSC. And when switching to an other channel the screen goes first blanck and then the video comes to the screen. We think that the interface is working,it is searching channels,but the screen blanking ist not correct.Can you help us to fix that.Is there a way to do that.My customer is not satisfied with that.
romano
Re: Problem with the Range Rover Evoque Interface
Postby Chortenia » 31 Oct 2012, 14:57
First try to connect another video source to check if the video interface is operating well.
If you can please provide video of situation you have described above.
Postby romano » 01 Nov 2012, 11:57
We have checked the interface with an other video source but with the same result. We think that the main reason is that this interface doesnt support PAL. In our country we use PAL,not NTSC.So what will be the solution?
romano
Postby Chortenia » 02 Nov 2012, 12:03
We received answer from this device manufacturer. They say that this device supports both PAL and NTSC.
So please make photo or video of connection where cable marks and places of cable connection can be seen.
Users browsing this forum: No registered users and 11 guests
