Vauxhall / Opel HELP!!!!
Postby sultan » 04 Dec 2012, 22:07
I've got a lexus interface v7.1 on the unit which I'm told by C-S that it will work, yet however I try settings, dip switches or gvif wire layouts i still cant get it to work, all I see is a blank screen when I press the change button no menus show up either.
I've also noted that the website says that V7.2 onwards is what works with the Insignia :|
PLEASE HELP ME!!!!! :cry: :cry: :cry: :cry: :cry: :cry:
Many Thanks
Rob
sultan
Car: Vauxhall Insignia
Re: Vauxhall / Opel HELP!!!!
Postby Chortenia » 05 Dec 2012, 11:01
Suppose this video interface fits for your car, is OEM image displayed after connection?
Where did you install the device, near OEM display or near DVD?
It will help us a lot if you provide pictures of installation.
Postby sultan » 05 Dec 2012, 11:21
I ordered the OPEL one and got the LEXUS one v7.1 .
Gregory told me it would work.
It is installed near the display ( I realise the connections on the in/out needed to be swapped as the connectors are meant to be changed at the radio but its quicker working at the display end) the oem display is shown after connection but will only show blank page when source button is pressed
Rob
sultan
Postby Chortenia » 05 Dec 2012, 11:42
Please, make photos of the interface module from the following sides: bottom, bar code side.
The photos should be good enough to read the inscriptions.
Postby sultan » 05 Dec 2012, 11:53
Underneath i know it has v 7.1 on the sticker.
This is the only picture I have at the moment due to being at work.
I can take more tonight.
Will I need to send this back?
sultan
Postby Chortenia » 05 Dec 2012, 12:45
We need bottom and side photos. After that we can tell whether you need to send the device back.
We need photos because video interface for Opel also has 7.1 version.
Postby sultan » 05 Dec 2012, 20:56
see attached photos
sultan
Postby Chortenia » 06 Dec 2012, 10:42
Please contact the manager (e.g. wrtite to email: gregory@car-solutions.com) to replace your video interface.
Postby sultan » 06 Dec 2012, 11:12
Whats the problem with the interface then?
sultan
Postby Chortenia » 06 Dec 2012, 11:34
Wrong interface was sent to you by mistake.
We appologize for the inconveniences.
Return to Video Interfaces for Lexus, Toyota, Land Rover
Users browsing this forum: No registered users and 11 guests
