GVIF v7 Range Rover, no Pic, no Menu
Postby marlan99 » 04 Feb 2013, 12:41
Hi There,
i received my GVIF with special Cable for my Range Rover MY 2007. Everythings seems ok instead that i can not see any Picture or GVIF Menu.
It stay black or white with some color noise. Are there different versions of the GVIF?
Any hint what i can test?
Original NAV works
CAN switch with the Button from the NAV works
Switch with the Remote works (but not the MENU)
Tested Input: AV2, AV3, REAR-C -> no Picture
regards
Marcel
marlan99
Car: RRS SC 2007
Re: GVIF v7 Range Rover, no Pic, no Menu
Postby Yuretz » 04 Feb 2013, 15:44
please provide order number.
Postby marlan99 » 04 Feb 2013, 16:30
Order Number: 2670625
Ordered: 29.12.2012
Received: 25.01.2013
marlan99
Car: RRS SC 2007
Postby Yuretz » 04 Feb 2013, 17:46
please, provide video where we can clearly see where the cables are going, marking of the cables, places of connection and what is displayed on the screen.
Postby marlan99 » 06 Feb 2013, 02:56
Hi Yuretz,
i tried to make the video:
http://www.youtube.com/watch?v=XLeN4NSuI64
in the last seconds of the video you can not see the Picture from the Rear Cam because of the Light.
So i had to stop the video disable the light and record again. This you will see here:
http://www.youtube.com/watch?v=0SZdVnQIN40
i hope you got what you need. otherwise just tell me.
thanks and regards
Marcel
marlan99
Car: RRS SC 2007
Postby Yuretz » 06 Feb 2013, 11:25
Where did you connect - near the monitor or navigation unit?
1. Swap places of LVDS in/out wire on the interface.
2. if it doesn't help - swap places of the red and yellow wires on the LVDS cable
3. The connected sources should support PAL format
Postby marlan99 » 11 Feb 2013, 14:50
Hi Yuretz,
thank you for the suggestions but it does not work.
1. Display says "no Nav available"
2. Display says "no Nav available"
3. Tested with PAL and NTSC Source. Same result
So when the GVIF is powerd an i can see and use the Original Navigation, the Cables are connected correctly.
I tried some different DIP Switch positions. At last i stayed with ON, ON, ON, ON, OFF, ON, ON, OFF.
This means for me all Sources are disabled (except CVBS4 for the Rear Cam with switch 7)
Switch 5 means used for Range Rover and Switch 6 means used with original Navigation.
When i try one of the Input AV1 - AV3 there are some disturbing colors (white with some colored lines) and when i power off the Cam the screen stays black.
Any other hint for the Dip Switch positions or the other Cables to use?
Otherwise it seems to be that this GVIF is not working.
regards
Marcel
marlan99
Car: RRS SC 2007
Postby Yuretz » 11 Feb 2013, 17:35
What will be the result if you do not connect the video source to the interface and turn the power on? Is the situation the same as if you connected camera or the screen is just black?
Postby marlan99 » 11 Feb 2013, 18:55
When i activate one of the AV1-3 inputs without a video source connected and then power on the gvif it switches immediatly to a black screen.
I can push the ok button from the remote and the Nav screen is back again.
With a video source connected the screen is white with some lines. I tried 3 different devices one NTSC format, one PAL and one device with a switch from NTSC to PAL. always the same white picture.
With the white screen and then push the MENU Button from the remote you can see more lines "walking" through the screen.
marlan99
Car: RRS SC 2007
Postby Yuretz » 12 Feb 2013, 10:51
As far as product repairs/change is concerned, please, contact your manager or Gregory via e-mail: gregory@car-solutions.com
Users browsing this forum: No registered users and 13 guests
