CAN doesn't work for E61 LCI 07/2009
Postby Bob » 15 Oct 2015, 13:54
i bought this Interface from your site "Product code: 850839". The REAR CAM doesn't work when putting REAR TYPE to CAN. I tried all CAR MODEL (F10 E90 2014 and E90).
By the way the guidlines works only with CAR MODEL (E90).
Please tell me what to do, because the CAM from your site "Product code: 819016" doesn't work when connected to the power of rear lamp, because when Motor starting the rear lamp power is only 11 Volt.
In the Manuals on site 23, they are talking about CAMERA TYPE, but in my Interface there isn't a menue for this.
I hope you can help me with These Problems.
Bob
Car: E61 2009
Re: CAN doesn't work for E61 LCI 07/2009
Postby Yuretz » 16 Oct 2015, 10:25
If PAS works then rear view camera activation should work also.
There is a socket marked "REAR" on the interface. You may use it to power up rear view camera or connect power according to this connection diagram - https://dl.dropboxusercontent.com/u/712 ... _OK_wm.png (grey wire is not needed to be connected in case of CAN connection).
There's no such function implemented in these interfaces yet.
Postby Bob » 17 Oct 2015, 00:36
i have after installing the cam another problem. The picture of the interface is like the attached picture. It is not clear. I tried more then one video source on all AVs and REAR-Input. It is still the same.
what is the problem?
best regards
Bob
Car: E61 2009
Postby milkancho » 18 Oct 2015, 14:04
I've had similar problem, the socket that plugs into the backside of the monitor wasn't all the way in. We pushed it a bit harder and the picture was ok. Good luck!
milkancho
Car: Opel
Postby Yuretz » 19 Oct 2015, 11:34
Bob wrote:Hello,
best regards
First of all try plugging in fully the connector which goes to the monitor suggested by milkancho.
Also, you may try resetting settings of the interface to default. To do this press and hold button "right" on the remote control for 5-6 seconds.
If the problem is still present then please describe how you powered an interface and additional devices up. Clear photos will be extremely helpful.
Postby Bob » 19 Oct 2015, 22:45
Ok thank you milkanchi i will try this tomorrow and will Report.
Bob
Car: E61 2009
Postby Bob » 21 Oct 2015, 21:37
Hello again,
the Problem with the noisy Picture is still available. i try to explain how i am connecting the Interface, and which Problems i have with it.
here are some pictures i made today from my Display. the pictures are from different modes.
This Picture Shows how the cable are connected
This Picture Shows how the enclosed connector is connected to the display
Here is AV1 running without videoinput, the text isn't readable
Here is AV1 running without videoinput, the menu also isn't readable
Here is the rearcam on, the Picture is too noisy
This is the normal menu of my car. normally there isn't any Problem. Some time like at this Picture, the Colors are distorted
Here is the rearcam on with pip of my PDC. if i turn on the guidlines is the Picture worser then this one.
Of Course i am doing the Suggestion of milkancho, but no improvement. Maybe the Interface is faulty? Please tell me what you think about that. If the Interface is faulty, how to Exchange.
Bob
Car: E61 2009
Postby Yuretz » 22 Oct 2015, 09:43
Have you tried plugging in fully the round connector - http://car-solutions.com/nfs/product/85 ... nes-11.jpg ?
Also:
try resetting settings of the interface to default. To do this press and hold button "right" on the remote control for 5-6 seconds;
try DIP switches #5 and #8 in different positions(put toggle in another position only when the inteface is powered off);
Postby Bob » 22 Oct 2015, 20:57
Yes i did, but no changes. It's still the same result.
If switching #5 in other position i only get a black display, when switching to rearcam or AV1, AV2 or AV3. if switching #8 in other position no changes.
I am now sure that the interface is faulty. So please send me a new one.
Bob
Car: E61 2009
Postby Yuretz » 23 Oct 2015, 10:10
Please contact sales department - http://car-solutions.com/en/information/contacts.html and provide the following information:
A. The car model and manufacture year:
B. Interface Information:
-Model :
-Version :
-Firmware date(barcode side) :
C. Problem in details:
D. Dip Switch Settings:
1: NAVI/RGB
2: A/V1
3: A/V2
4: A/V3
5:
6:
7: Camera
8:
E. Tried to Solve :
F. Photo & Video of installation & Problem(If possible, It would be very helpful)
Return to Video Interfaces for BMW
Users browsing this forum: No registered users and 11 guests
