A few issues.
1. On Power/ CAN cable, there are now 2 sets of CAN wires. CAN IN and CAN OUT. What are CAN OUT for? These are not shown on manual.
2. MENU SETTINGS - (5) AV1 (Front View) Settings, Parking Distance Control is NOT selectable to allow setting, even though manual says it should be! How do I correct this? I want front view cam to display as advertised but also front PDC to display on screen.
3. IDRIVE CONTROL.
To change MODES, Menu button long press works.
LEFT PUSH - does not function at all! Why not?
RIGHT PUSH - Gives FULL and PIP mode 1 only, NO PIP Mode 2. Why not?
Once in PIP 1 mode system locks up and will not return to FULL mode, only way out is to hold OPTIONS button and then do reset.
How to sort this?
LEFT PUSH Does not function at all. How to sort this?
As you can see a good few issues. Unit is correctly connected as per your instructions, CAN high and low connected and tested as okay.
DIP Switch Settings:
1- OFF
2- OFF
3- OFF
4- ON
5- ON
6- OFF
7- OFF
8- OFF
9- OFF
10- OFF
Can someone possibly assist?
Firmware 2015-10-13
