how can i control AV sources (DVD, DVB-T) by iDrive
Postby muzica9 » 28 May 2012, 17:29
Hi! i've just bought this
http://www.gsmserver.com/shop/car/car_v ... upport.php
how can i control AV sources (DVD, Navi) by iDrive?
is this function optional. if it's optional, what is the difference.
also, CABLES labeled AV1SEL AV2SEL AV3SEL what they are used for?
muzica9
Re: how can i control AV sources (DVD, DVB-T) by iDrive
Postby Germes » 29 May 2012, 11:09
AV1-SEL - 12Volt power comes out from wire by AV1 mode – MAXIMUM power available is 500 mA!!!!!
AV2-SEL - 12Volt power comes out from wire by AV2 mode – MAXIMUM power available is 500 mA!!!!!
AV3-SEL - 12Volt power comes out from wire by AV3 mode – MAXIMUM power available is 500 mA!!!!!
NAVI-SEL - 12Volt power comes out from wire by NAVI mode – MAXIMUM power available is 500 mA!!!!!
SAFE - connect to GND (power wires or to car chassis) for enable picture in motion (picture from video interface)
Postby muzica9 » 29 May 2012, 13:04
thanks. and to control AV sources (DVD, Navi) by iDrive?
muzica9
Postby Chortenia » 31 May 2012, 09:55
This video interface can control only some types of DVD players, namely made by Alpine.
To do this connect white wire DVD IR from RGB IN connector to signal wire of DVD player IR receiver.
Postby drmahmoud1981 » 11 Jun 2013, 18:31
Hi i get this:
http://car-solutions.com/en/cs9200rv-na ... nitors.php
and this:
http://car-solutions.com/en/car-video-i ... upport.php
1-i want to control the navigation box by the iDrive. I tried to connect the IR navi wire of the video interface to the signal wire of the Navigation box IR port but it cant get anything.
2- if i used a canbus interface to convert the can signal from iDrive to analogue signal how can i connect it to the navigation box
3- what is the Rx Tx wires of the date cable is for? to control what and is it out or in cables
drmahmoud1981
Car: BMW e90 2008 with iD
Postby Chortenia » 18 Jun 2013, 12:52
1. It's not possible. You can use only remote control or touch screen panel for control.
2. -
3. It is used for control. In fact you need only RX. If you connect the touch screen panel, you will also need the USB controller or direct connection if the CS9200 has the corresponding 4 pin input.
Postby Cedric » 10 Mar 2014, 00:45
Could you send links of compatible RGB players that allow control of the DVD via Idrive? I have CAN Multimedia Video Interface V.4.
What specifications must have the DVD player?
Thanks!
Cedric.
Cedric
Car: BMW
Postby Chortenia » 11 Mar 2014, 11:02
Hello
Please, provide the link to the interface.
There are no RGB players in our goods range.
Users browsing this forum: No registered users and 8 guests
