Ford escape 2011
Ford escape 2011
Postby whadi » 11 Jan 2015, 21:00
I would like to buy a video interface Lincoln Navigator because it is
compatible with my car and CS9320CE navigation box.
So if you can describe how can I connect them in my car. I read the manual but still vague.
Thanks a lot
whadi
Car: Ford Escape
Re: Ford escape 2011
Postby Chortenia » 12 Jan 2015, 16:18
Dismantle the head unit, find 60 pin cable, which goes from the matrix to the board. Take it out and connect it to the following board
using the following adapter with the FFC
Image (the one, which is 60pin)
The other side of the FFc should go back to the OEM board.
Do the same with touch.
Postby whadi » 16 Jan 2015, 21:40
Is there a video for that
whadi
Car: Ford Escape
Postby Yuretz » 19 Jan 2015, 11:38
whadi wrote:Hi.
Unfortunately, we have no video of installation.
Postby whadi » 26 Jan 2015, 16:18
I connected PNL to touch panel direct, and PCB cable , original touch cable with converter.
is this correct or not.
whadi
Car: Ford Escape
Postby Chortenia » 27 Jan 2015, 12:10
Yes, it's correct.
Return to Other
