new CS9100 Won't work for first time on 2004 Lexus 430
Postby nasser » 04 Jun 2012, 21:25
My new CS9100 won't work properly on my 2004 Lexus 430 LS.
I have contacted by e-mail the tech support team and got an initial response but none afterwards despite several follow up messages :( !
Aftet installing/connecting/initializing/synchronizing ... etc the system as per the instruction procedures, the only system response I get is a windows-like start up tone but no visual acreen output at all! The screen shows the message "external system not connected">
Since my attempts to contact the support team seem to have gone into a black-hole, I thought someone in this forum can be helpful. Please!
nasser
Re: new CS9100 Won't work for first time on 2004 Lexus 430
Postby Chortenia » 05 Jun 2012, 12:08
Please, make photo of connection for us to see where the wires are connected.
Postby nasser » 05 Jun 2012, 14:45
Thanks Chortenia for the reply. I truly appreciate your response. The attached Word file has the e-mail messages I exchanged with the tech support team. The file should give you a clear description of the problem.
The 14 pictures I sent are also attached in the RAR archive.
Video files for further details can be downloaded from the below links because they are too large to be attached. The links are also found in the Word file attached since I had sent them before to the tech support team.
As I have double-checked the connections several times, I feel the CS9100 system I recieved might be defective. I was hoping to have a better experience, if not from the CS9100 at least from the support quality. I was actually planning, if successful, to buy few as gifts for friends. You may,Chortenia, restore my hope :)
Thanks again for the reply and in advance for the help!
Nasser
http://www.2shared.com/video/06I0BXVw/C ... tions.html
http://www.2shared.com/video/Pck5l7GY/C ... board.html
http://www.2shared.com/video/h_nBjyjc/C ... ector.html
http://www.2shared.com/video/IQRcGtZ3/C ... ed_Co.html
http://www.2shared.com/video/ggYvgfyr/C ... nd_co.html
14 Pictures.rar
(6.5 MiB) Downloaded 2517 times
e-mails with tech support of car-solutions.docx
(19.72 KiB) Downloaded 3100 times
nasser
Postby Chortenia » 07 Jun 2012, 09:54
Try to swap the places of wires that go to AVC-LAN+ & AVC-LAN-.
Please, write if it helped.
If it does not help, you will need to replace NAV2NAV controller.
Postby nasser » 07 Jun 2012, 23:50
Thanks a million Chortenia for the reply.
I will try it first thing tomorrow (God willing) and let you know the outcome. I assume you want me to swap points 2 & 12 on the NAV2NAV. Right?
Nasser
nasser
Postby Chortenia » 08 Jun 2012, 09:26
Yes, you are right!
Please, do it and tell us if it helped you!
Postby nasser » 10 Jun 2012, 23:31
Hi Chortenia
Unfortunately, swapping points 2 & 12 changed nothing :( !
I assume you have reviewed the pictures I sent you and have not identified any problems. I understand that you recommend changing the NAV2NAV. Can you suggest any test to rule out/in the possibility of a defective NAV2NAV before returning it? If no, then what is the procedure for returning the item?
Thx.
Nasser
nasser
Postby Chortenia » 12 Jun 2012, 10:42
Hello Nasser!
We will replace your NAV2NAV adapter!
Our technical support specialist will contact you via email you provided in the screenshots.
Please, when you receive and install your new adapter, inform us if everything works well.
Postby nasser » 12 Jun 2012, 19:48
Thanks Chortenia a lot.
I did get an e-mail message & will surely keep you posted on the results. Thanks.
nasser
Postby nasser » 29 Jun 2012, 11:00
Hi Chortenia
Per e-mail message, I shipped the NAV2NAV & it was delivered few days ago (accoeding to EMS). I have not yet heard from from the tech support. FYI & in case you would be able to help again!
nasser
Postby nasser » 29 Jun 2012, 12:53
Please be informed that I just got a reply that it was received & a new one will be shipped. Thx.
nasser
Postby Chortenia » 29 Jun 2012, 16:31
Dear Nasser!
I'm pleased to hear that.
Please, inform us when you receive new device and install it to your car.
Postby snnar » 09 Dec 2012, 00:07
I found the solution to this problem
Tomorrow provide you plan connection
snnar
Car: toyota
