CS9100 for Toyota Touch&Go
Posted: 29 Jan 2014, 20:07
I installed successfully CS9100 Touch&Go set (Car Solution Edition) for several nav units (59026 Verso, 19006 Yaris).
On these units there is a MAP/nav button, the installed navigation is activated by double push of the Power button.
Now I tried to install the same set for Prius 57037 unit with JBL, it also has MAP/nav button.
Unfortunately the Power button doesn't activate the external unit screen.
How to fix it?
The next work will be a 2013 Rav4 with 53888 T&Go unit, but on this unit there is only a NAV button, not MAP/nav.
Will this set work with this unit?
How to fix it?
