Video Interface BMW PIP IDRV, CS9100, BMW X5 2007 6.5”
Postby Stanley » 07 Jun 2011, 13:02
my car: BMW X5 año 2007 con pantalla de 6.5”
I connected CS9100, Multimedia Video Interface for BMW with PIP function (IDRV support).
When I start the engine fist time - everithing is working perfectly, but when some time passes, image get spoiled like I send you here at the picture. And then we will need to restart the system to get good quality again. But not every time we restart the system we get a good quality. It seems like some component in CS9100 or in Video interface is not working properly.
Please let know if you need addicional information.
thank you
Re: Video Interface BMW PIP IDRV, CS9100, BMW X5 2007 6.5”
Postby Stanley » 07 Jun 2011, 16:39
hi once again!
here are answers to your questions:
1. How is video signal connected from CS9100 to video interface? By RCA or RGB?
- It is connected by RGB. We also tried by RCA, and it picture was even worse this way.
2. If by RCA, please confirm if the cable was of good quality.
- Yes, I confirm, cable was of good quality
3. If by RGB, please let us know if you extended the cable and did you connect it to GND?
- We did not extend it. I just edjusted distance of two connectors. Yes I connected to MASA.
4. What is power supply for Video Interface? Did you connect one ACC with “+” and another (GND) with case?
- Video interface takes power from “cigarette lighter” (15 AMP). It is the only plase where we can take good enough feeding. And Masa – directly to screw in a vehicle.
5. What is power supply for CS9100? Did you connect one ACC with “+” and another (GND) with case?
- we tried 2 ways. 1 – to “cigarette lighter”. 2 – with the same cable from Video interface (navi – blue cable). Masa – with the car-body.
6. Do Cs9100 and Video interface take power from the same place?
- As I already told we tried both – from the same place and directly from the battery.
