2008 Infiniti M: Connecting CS-9100 and Car Video Interface
Postby gr8rides » 08 Mar 2012, 22:11
Can someone please explain how the audio (L/R channel) from CS-9100 NAV and other external sources like DVD be connected to the Car Video Interface for Infiniti M (AV1, AV2) or to the OEM factory system so that the audio can be heard. Is there a way to avoid having to install the external speaker that is provided. Even if so, still leaves out other sources like an external vido source like a DVD without L/R audio in.
Does the mode feature work? Can I connect the wire for mode to the button on the dash and how?
How does "ADO SEL" be configured? When is it used?
gr8rides
Re: 2008 Infiniti M: Connecting CS-9100 and Car Video Interf
Postby Chortenia » 29 Mar 2012, 10:41
If your car is equipped with AUX input you can use it. If not, you will need to organize such input.
