by juergen » 14 Mar 2013, 15:28
Ok. The Radio does not switch to the guide voice when, for examlpe, i am using the tuner as audio source und the CS9100 (i use iGo8) makes a new direction.
My only explanation for this is, that there may be something with the guide control signal or wire. So if you can tel me, if the Alpine cable harness has the guide control wire connected or not.
I have read somewhere in the internet, that the two wires that came out of the back of the data cable conector at the box are for video and guide control, but i can not find any info, if the CS9100 support guide control and if it is connected to the pin1 labeled wire at the the back of the mini-DIN plug.
When i set my radio to 'navi mix', the audio source is switche to an lower audio volume when a guide direction came, but i can not hear it. After the command the volume is switched back.
When i select the S9100 as main source, audio playback is working perfectly.
I'll try to make a video from this butthis may take some time. Happily i can use the navigation demo mode of iGo8 so i do not need to drive for this, because usig a cellphone, no matter how you use it, when driving is illegal here...
