Activate a menu of English blue CS9200RV
Postby snnar » 08 Dec 2012, 12:25
I have a blue menu in English
How to install and activate Instead of the current menu black
snnar
Car: toyota
Re: Activate a menu of English blue CS9200RV
Postby snnar » 08 Dec 2012, 23:41
Device CS9200RV
snnar
Car: toyota
Postby Chortenia » 10 Dec 2012, 11:41
Set the following to autorun: System->Auto Run Navi ON, select Navi path: SDMMC Disk/Menu/Menu.exe
Postby camil9 » 22 Aug 2013, 01:21
where to download different menu?
camil9
Car: Ford Focus RS
Postby jbss » 17 Apr 2014, 05:05
I have the Menu files, but cannot get the navigation software to run properly under the menu. It runs once, then on second attempt says it can't find the global cfg file (IGO Primo). How do you setup the icon on the main menu for this to work?
jbss
Car: TOUAREG
Postby Chortenia » 17 Apr 2014, 11:26
The menu doesn't have the impact on iGo. Check, whether global cfg folder is for /igo/content and whether it is designed for this build.
If you press the icon, you will see the pop-down menu, through which you can set the path to the file and much more.
Users browsing this forum: Google [Bot] and 3 guests
