How To Reset cs9200?
Postby maxslick » 08 Jun 2013, 06:05
How do I reset the cs9200 to factory settings? I have chosen the wrong resolution for the monitor and now I can't see anything.
I have a cs9200 multimedia box connected to a rhoson in dash monitor (http://car-solutions.com/en/car-6.5-tft ... utback.php).
Your help is kindly appreciated.
Kind regards,
Max
maxslick
Car: Subaru
Re: How To Reset cs9200?
Postby maxslick » 08 Jun 2013, 06:36
Never mind this post. I managed to navigate my way through the fuzzy screen due to the incorrect resolution and select the right one. All good now.
maxslick
Car: Subaru
Postby Chortenia » 11 Jun 2013, 16:17
We are glad that everything is ok.
Please, don't hesitate to ask questions if any arise.
Postby kikasso » 13 Oct 2014, 21:03
got to put the resolution as well also change it and now I get the lines of colors and will not let me put it right
lo pongo en español tambien e cambiado la resolucion a pal-n y ahora solo salen rayas de colores que puedo hacer?
kikasso
Car: opel vectra c
Postby Chortenia » 14 Oct 2014, 10:34
Can you give us the photo of the problem, please.
Postby kikasso » 14 Oct 2014, 23:28
ok thanks will try to send photos
kikasso
Car: opel vectra c
Postby kikasso » 14 Oct 2014, 23:33
not if you got the pictures?
kikasso
Car: opel vectra c
Postby Chortenia » 15 Oct 2014, 11:18
Where did you send them?
Postby kikasso » 15 Oct 2014, 23:46
kikasso
Car: opel vectra c
Postby Chortenia » 16 Oct 2014, 10:38
Please, indicate the model and model year of the car. How is box connected (via interface or directly)? What is set in Panel and Resolution?
Postby kikasso » 16 Oct 2014, 18:35
9200 is the direct interface plugged into a
my car is a vectra c 2005 to 9200 is the interface to the screen and the Color cid 16/9 "
worked well but I was looking in settings because I wanted to connect the iphone to watch videos and you touch settings put pal-N and the image was out of the picture
forgive me for not English and write in Spanish in the google translator
kikasso
Car: opel vectra c
Postby Chortenia » 17 Oct 2014, 16:28
Connect it to the video interface or TV/monitor via CVBS, go to settings and make everything how it was before.
Postby kikasso » 17 Oct 2014, 16:56
thank you very much I'll try
What for iphone videos on 9200 that I have to do, buy a cable for iphone and white rca output. I amarillo.rojo?
kikasso
Car: opel vectra c
Postby Chortenia » 17 Oct 2014, 17:54
To display the image from iPhone you will need this cable. connect it using this adapter to the corresponding socket.
Postby kikasso » 17 Oct 2014, 19:41
this is the cable that I have and so I plug in the front but is not listening can not hear
kikasso
Car: opel vectra c
