MAP/Navi Button
MAP/Navi Button
Postby cpkiewiet » 21 Dec 2014, 01:53
Is the navigation program functioning by pressing the MAP/NAVI button, if i correctly entered the correct path and file in the wince menu, or do i have to associate the nav program executable with a special file in the root of the SD-card ?
Is it, under normal circumstances, possible to control the menu of the navigation box with the touch screen or do i need special hardware for this ?
Thanks in advance
cpkiewiet
Car: toyota verso s
Re: MAP/Navi Button
Postby Chortenia » 22 Dec 2014, 11:15
You can out navigation software on autorun in System menu. Thus when the 9200 starts, navigation program starts automatically. In the same menu you set the path to the navigation software.
You can control it using the touch screen. Go to the menu, select Panel, there select the correct control protocol.
Here is the manual.
