Rear View Camera
Rear View Camera
Postby 247stu » 08 Feb 2015, 18:31
I am trying to make rear view camera work in a new menu I have discovered that when using default program screen I can access an image using AV in and a second image using Rear view camera. However when mapping my new buttons to 1,AVin.exe this works perfect but trying to use 2, Rear.exe the button does nothing can you help I have attached links to the menu zip and 2 videos showing my predicament really appreciate your help
https://www.dropbox.com/s/ov4acrk0yw114b8/menu.zip?dl=0
https://www.dropbox.com/s/akaoh1gl2k1gp ... 0.3gp?dl=0
https://www.dropbox.com/s/t3rigrjk01f42 ... 9.3gp?dl=0
247stu
Car: Discovery3
Re: Rear View Camera
Postby Chortenia » 12 Feb 2015, 18:50
Rear.exe is not triggered by launch. It is triggered when +12V are applied to the corresponding wire.
Postby 247stu » 12 Feb 2015, 21:33
Thanks for the reply how is rear camera triggered on the menu I want to use both rear camera and AVin to look at 2 off forward looking camera by using 2 off button in my new menu ??
247stu
Car: Discovery3
Postby Chortenia » 13 Feb 2015, 11:44
If the system sees that +12 V appear on the certain wire, it launches rear.exe file, which in its turn gives image from input 1. AVin program launches image from input 2. It's embedded into the stock firmware of the box. We can do nothing about it.
I mean, it is necessary to develop a program like AVin, which will use input 1. Unfortunately, we can't do it for now.
Users browsing this forum: No registered users and 19 guests
