CS9200RV
CS9200RV
Postby 34by151 » 04 Oct 2012, 12:24
Is there a manual for the CS9200RV
Product code: 835756
http://car-solutions.com/en/cs9200rv-na ... nitors.php
The link on the website is for the CS9200 and this differs from the RV
Can you also explain the function of the "Mic" Socket?
Can you send me the functions for the Data, RGB and Power cable
PS I connecting the CS9200RV to the Universal RGB Low-End Car Video Interface (Product code:818548)
http://car-solutions.com/en/universal-r ... erface.php
And the Multifunctional Universal Touch Screen Controller TSC-206IM (Product code: 837018)
http://car-solutions.com/en/multifuncti ... -206im.php
I also have the
IR Receiver for TSC-206IM Touch Screen Controller (Product code: 837248)
http://car-solutions.com/en/ir-receiver ... roller.php
SerPro System Interface Controller (Product code: 837249)
http://car-solutions.com/en/serpro-syst ... roller.php
Cable for TSC-206IM Connection to SerPro System Interface Controller (Product code: 837250)
http://car-solutions.com/en/cable-for-t ... roller.php
Trying to work out how to connect
CS9200RV with TSC-206IM
CS9200RV with Video Interface
Video Interface with OEM screen, OEM Nav, CS9200RV, Reverse camera
34by151
34by151
Car: Jaguar XJR
Re: CS9200RV
Postby Chortenia » 04 Oct 2012, 13:44
CS9200RV navigation box differs from CS9200 only by video input availability. The manual is for CS9200RV and unfortunately we don't have another one.
Here is RGB and data cable pinout
UART cable pinout:
Re: CS9200RV
Postby 34by151 » 04 Oct 2012, 14:10
OK Thanks, but what is in the manual differs from what is written on the cables
This is what I have
Data Cable
12V out RED
PIP in BLUE
REVERSE GREEN
VIDEO SW WHITE
GROUND BLACK
AGND BROWN
MUTE RED
TOUCH RX YELLOW
1. So 12v on "REVERSE" enables Video 2
2. So 12v on "VIDEO SW" enables Video 1
3. So "TOUCH RX" connects to the TSC-206IM pin J3 Navi RX, but,
Where is the "Touch TX" to connect to the TSC-206IM pin J4?
4. Is "12V out" switched on/off by some function?
5. What does "PIP in" in do?
6. What is "AGND" do?
RGB Cable
AUDIO L ORANGE
AUDIO R BROWN
SYNC YELLOW
R RED
G GREEN
B BLUE
GND BLACK
IR DATA WHITE
VCC RED
1. Is Audio L & R the same as the SPK connection on the rear of the box?
2. Does the "IR DATA" connect to the TSC-206IM? and if not what is it used for?
3. Does VCC connect to ACC or BAT?
34by151
34by151
Car: Jaguar XJR
Re: CS9200RV
Postby Chortenia » 04 Oct 2012, 15:02
No, speaker output is used for connection of the speaker included in the package (providing amplified mono signal to the speaker from the package).
It's not used
3.Does VCC connect to ACC or BAT?
To ACC.
Re: CS9200RV
Postby 34by151 » 04 Oct 2012, 15:18
Thanks for that but on the data cable I have
12V out RED
PIP in BLUE
REVERSE GREEN
VIDEO SW WHITE
GROUND BLACK
AGND BROWN
MUTE RED
TOUCH RX YELLOW
6. What does "AGND" do?
34by151
Car: Jaguar XJR
Re: CS9200RV
Postby Chortenia » 04 Oct 2012, 15:48
Please, name your car brand, model, model year and which region it was made for.
Also please provide photos of head unit from the connectors side.
Re: CS9200RV
Postby 34by151 » 04 Oct 2012, 15:56
For the record I have a 2004 Jaguar XJR, X350
I don’t have an issue with connecting the video interface or the RV to the video interface.
The video interface (details in first post), is connected in the boot with the OEM nav.
At present I have the reverse and side cameras working with that without any problems.
I am connecting the RV to the interface next and the TSC-206IM to the RV and OEM head unit
Interfacing the RGBS signals I have sorted out
Can you please send the info for
34by151
Car: Jaguar XJR
Re: CS9200RV
Postby Chortenia » 04 Oct 2012, 16:41
Is not used in your case
Not understandable (incorrect pinout)
You should check continuity of 3,4 pins of the cable and everything will fit together (pinout was provided earlier)
4. Don’t use additional +12V for TSC-206IM powering, put power to touch adapter directly from the ACC
Apply to the specialists to avoid possible damages to your car.
Re: CS9200RV
Postby 34by151 » 08 Oct 2012, 14:02
We are the specialists, this is not the only product being interrogated and and we cant bring the customers car in till we can figure it all out first. I can send you all the system circuit diagrams if they helps you but we just need confirmation on the Data cable
It seems we have been shipped the DATA cable with incorrect labels
Here is what we have as compared to the 9200 pin out
Supplied Cable
1 Red1 Mute
2 Green Reverse
3 Black No tag
4 Yellow Touch RX
5 Blue PIP in
6 White Video Sw
7 Red2 12V out
8 Brown A Gnd
CS9022 Manual
1 Ext3
2 Ext4
3 Ext2
4 Ext1
5 PTP_IN
6 VCC_EXTSWDC
7 VCC_EXT
8 GND_D
So you are saying
Pin 3 (ext2) is Touch RX
Pin 4 (ext2) is Touch TX
Is Pin 2 (ext4) reverse correct?
Does Pin 6 (VCC_EXTSWDC) switch the aux video on?
Is Pin 5 PIP as on the cable or PTP as on the 9200? Ie does this allow picture in picture (PIP) and if not wat does PTP mean?
34by151
Car: Jaguar XJR
Re: CS9200RV
Postby Chortenia » 08 Oct 2012, 15:46
You need only 3,4 and 8 pins.
6 pin is not used
2 pin – for reverse camera activation. Not used in your case
5 pin is not used
Re: CS9200RV
Postby 34by151 » 08 Oct 2012, 22:56
I will be using both video inputs, that’s one of the reasons for the RV
In fact we are using 4 cvbs video inputs 2 from the rv and 2 on the video interface LE
The 2 video inputs on the RV connect to information systems which can trigger and external display such as the RV
For the RV
We will activate V2 with pin 2
Please confirm is V1 can be activated with pin 6
34by151
Car: Jaguar XJR
Re: CS9200RV
Postby Chortenia » 09 Oct 2012, 11:52
You can activate V2 by applying +12V on pin2
V1 can be activated only in the navigation box menu
