Choose the Software Navigation
Postby antonello » 18 Mar 2013, 11:28
Does iGO Primo 2.4 doe Win CE6.0 works with CS9200RV ?
The Navy software support the 800x480 map resolution but from the manual is not 100% clear if CS9200RV can read them.
In case IGO Primo 2.4 is a suitable software, could you please tell me how to configure the following in CS9200RV:
RGB ADJUST:
My ideea is the following:
H - Size: 480
CVBS ADJUST:
PAL - BDGHI (I'm using the system in Italy)
Width: 800
Height: 480
PANEL
4 pin touch
Select -> 800x480
RESOLUTION
Select -> 800x480
lease find attached the connection scheme.
Best Regards,
Antonello
CS9200RV_Video interface.doc
(25.5 KiB) Downloaded 2592 times
antonello
Car: AUDI A4
Re: Choose the Software Navigation
Postby Chortenia » 18 Mar 2013, 12:27
The CS9200 supports resolution up to 800х480.
We didn't install IGO Primo, however, we can help you with IGO 8.3.
Postby antonello » 19 Mar 2013, 14:57
Could you also please tell me if the proposed configuration in CS9200RV, in principle, are correct ?
Best Regards,
Antonello
antonello
Car: AUDI A4
Postby Chortenia » 19 Mar 2013, 17:03
The configuration is not correct for your case. You will use USB touch screen adapter, so the protocol should be not 4 pin touch, but eeti usb touch. As far as connection scheme is concerned, the CS9200 has RGB output and the interface has the input. It’s better to connect them in such way since the image via the composite output will be much worse.
