Problems with my CS9200
Postby velecin » 22 Apr 2013, 15:30
I have some problems with my CS9200
- I can´t install any program. Is there any way to install applications (photo viewer, word, pdf ...)?
- I can not watch videos, I can only listen. What are the video formats accepted the CS9200? How can I watch videos?
- Today I turned off the CS9200 with the "Power" button on the remote control and then I have not been able to turn on it. How can I turn it on with the remote control??
velecin
Car: Range Rover Evoque
Re: Problems with my CS9200
Postby Chortenia » 23 Apr 2013, 12:36
1. You don't need to install the programs, just save them on the memory card and run.
2. Use video player with codecs, e.g. TCPMP
3. Turn it on in the same way. Push power button and hold it for more than 2 seconds
Postby velecin » 23 Apr 2013, 13:08
Ok!!
Thank you very much.
Kind regards
velecin
Postby velecin » 29 Apr 2013, 12:58
Hi!! I have installed a CS9200 in my Range Rover Evoque and I have problems with sounds: original radio always sounds while the CS9200 with GPS function. I don't know to make a correct conection to turn off the original radio when GPS es running. Can you tell me which es the correct connection???
velecin
Postby Chortenia » 29 Apr 2013, 17:15
There is no mute signal in the Evoque. So there is no way to do so (at least according to our information).
Postby velecin » 29 Apr 2013, 17:30
So can not I listen to music from CS9200, GPS instructions ... through the speakers of my car????? :shock:
velecin
Postby Chortenia » 30 Apr 2013, 10:54
You can transfer the sound to the car speakers through the AUX IN.
Postby velecin » 30 Apr 2013, 11:08
Ok!!! I will try it.
velecin
