CS9100 with Alpine Monitor (Touch Screen)
Posted: 02 Jun 2012, 10:18
The Monitor model is M7T that Alpine OEM for Mitsubishi Pajero Sport. I ordered CS9100 together with Alpine Cable from your site. My monitor M7T has NAVI pinout as showing in below picture
I already check by Ohm-Meter. The Monitor PCB (I opened the box) labeling pins description. Once I connected the Alpine Cable and power on the CS9100, the Monitor showing menu in bad displaying maybe display format regarding your spec sending NTSC format.
My questions are;
1) I think my M7T monitor is PAL format so, will it work with your CS9100? If not, have any idea or can CS9100 configure to send video in PAL format?
2) Touch panel does not work. There is no response while touching any menu on the M7T monitor. How can I fix?
I already config the interface to "Alpine" . I tested by connect the CS9100 to my LCD TV, insert USB mouse and configure/settings there.
Please help.
Thanks in advance,
Sakarin
My questions are;
Please help.
Thanks in advance,
Sakarin
