Internet browser
Internet browser
Postby antonello » 26 Mar 2013, 16:00
Good afternoon,
I have installed the CS9200RV navy box and it works fine.
I'd like to Connect it to internet (via a wifi) now by Internet Explorer windows browser or other browsers.
For the Connection to the wifi network I had no problems at all but once a push the IE icon tien a blocking worning Message come (unfortunately it' s unreadeable beccasse the monitor resolution I have) and I cannot proceed further.
How can I proceed to have access to IE or to install another browser? (In this second case Which alternative do you suggest?)
For the wifi Connection I'm using your USB key purchased with cs9200 box.
Antonello
antonello
Car: AUDI A4
Re: Internet browser
Postby Chortenia » 26 Mar 2013, 17:03
Unfortunately, the manufacturer removed Internet Explorer in the new firmware, however, you can use any other available browser for WIN CE 6.0. For example, you can use Opera
but you won't be able to launch it from the OEM menu.
Postby antonello » 27 Mar 2013, 10:37
I suppose then that the only way to launch it from the 'Explorer' menù. Is this correct?
If the 'IE' icon cannot be' used, is there any possibility to add a new icon in the menù and launch Opera from it?
I heard something about the possibility to change menù layout and I'm wondering if editing some config. file will be possible to make life easy when on board of my car.
Antonello
antonello
Car: AUDI A4
Postby Yuretz » 27 Mar 2013, 15:48
Just rename opera-mini.exe to adzoommt-armv4i.exe.
Postby antonello » 27 Mar 2013, 15:58
Great!
Regards
Antonello
antonello
Car: AUDI A4
Return to CS9100/CS9200 Connection to Internet
