ARABIC letters on CS9900
16 Feb 2014, 12:47
by hatimym
hi there
I did install CS9900 in my car land cruiser 2010 via video interface and every thing work good
but only I have one problem with ARABIC letters when I using Google web or play ... the Arabic letters should be together but they appeared separated
is there an update to solve this problem
Re: ARABIC letters on CS9900
17 Feb 2014, 18:43
This is an Android 2.3 problem. There were no official solutions for that.
You can take a look on
this or similar solutions.
18 Feb 2014, 10:59
by hatimym
thanks
what I have to do ... just install it in my CS9900 ???
is there any dangerous ??? it said in the google play (it may cause boot-loops or other issues) .. is this will destroy my cs9900
please I need your advice about this
18 Feb 2014, 18:20
As we can judge from the description, you will also need to root the device. You can do it using "unlockroot" or similar program. However, keep in mind that you are doing it at your own risk.
In any case if there will be a boot loop, you can replace the firmware from the SD card or using the special program.
However, it's unlikely that the box will get out of order.
19 Feb 2014, 20:49
by hatimym
thanks
I don't know about root and unlockroot
so I think you have a box for testing right ??
if yes , could you try to install it in yours because you are qualify to fix any problems than me ... I will very thank full
if not I will also thank you about your time
