Bluetooth Cable
Bluetooth Cable
Postby 34by151 » 01 Apr 2013, 12:52
I have the bluetooth cable part no 834759
I can not see in the manual how you enable or setup the uart port like you do with the 9200/9200RV
Can you send details on how to setup the cable
34by151
Car: Jaguar XJR
Re: Bluetooth Cable
Postby Chortenia » 02 Apr 2013, 11:29
This cable is not compatible with CS9900 navigation box.
Please, contact the manager concerning its substitution.
Re: Bluetooth Cable
Postby 34by151 » 03 Apr 2013, 10:12
So why is it listed on this website as the correct cable
Please supply the link and part number of the correct cable
Can you also answer the question re setup of the uart as it is not covered in the manual
34by151
Car: Jaguar XJR
Re: Bluetooth Cable
Postby Chortenia » 03 Apr 2013, 12:08
It's a mistake.
CS9900 is compatible with most USB Bluetooth adapters. Unfortunately, we don't have the ones in stock.
To setup go to wireless & networks->bluetooth settings.
UART cables are not compatible. You need the USB stick or adapter.
Re: Bluetooth Cable
Postby 34by151 » 04 Apr 2013, 14:02
Ok, So I have a usb bluetooth dongle that is android compatible
If I add this and setup the bluetooth, I can then pair my phone and have the calls on the 9900
I assume the mic connector is then used for the phone mic
34by151
Car: Jaguar XJR
Re: Bluetooth Cable
Postby Chortenia » 08 Apr 2013, 12:31
Unfortunately, this revision of the hardware does not support such function.
Re: Bluetooth Cable
Postby 34by151 » 09 Apr 2013, 15:05
So you are now saying it does not support handsfree calls from your phone
I'd suggest you correct your website as indicating otherwise and listing the cable to do so is at best misleading
34by151
Car: Jaguar XJR
Re: Bluetooth Cable
Postby Chortenia » 10 Apr 2013, 10:43
Thank you for helping us to clarify this situation. We apologize for the inconveniences!
Return to CS9900 Navigation Box
