by hslava » 15 Nov 2012, 17:37
Hi all. I am designer of the TSC206IM device.
Now i have uploaded a new release of software. All you need is in the one pack TSC206 updates.zip. The stepwise manual too.Good luck, And two important notes:
first. To update firmware and set working parameters of TSC206IM you need use my programming adaptor. To do this your PC must support USB1.1. If not, updating and parameters setting will be unavailable. Now i amsolving this problem by making new device that will support USB2.0 protocol.
second. Never use ungrounded AC/DC converters to supply power to controller. Otherwise this can damage device when you touch any conponent by your finger, because of puls of volage will be generated. Your finger is grounded.
Thanks. Good luck.
PS. I attached an instruction manual too.
- Attachments
TSC-206IM_manual.pdf
- (494 KiB) Downloaded 3098 times
TSC206 updates.zip
- (1.49 MiB) Downloaded 2449 times
