How can I install drivers in my CS9200R??
USB touch screen controller in combination with touch screen panel simplifies user interface and control of various devices. It enables, for example, additional navigation unit or CarPC touch screen control on car built-in monitor.
Postby velecin » 16 Apr 2013, 11:53
Hi!!
I already have the drivers wince 6.
How can I install drivers in my CS9200R?? Have you got any manual for this???
velecin
Car: Range Rover Evoque
Re: How can I install drivers in my CS9200R??
Postby Chortenia » 16 Apr 2013, 11:59
What drivers exactly do you want to install?
Postby velecin » 16 Apr 2013, 17:38
Chortenia wrote:Hello!
I want to install drivers wince 6 for http://car-solutions.com/en/usb-touch-s ... roller.php
I think to have saw a manual in your web but I don´t find it.
velecin
Postby Chortenia » 17 Apr 2013, 09:15
Drivers for touch screen controller are already installed in CS9200.
Postby velecin » 17 Apr 2013, 09:57
Ok!!!
velecin
Postby Chortenia » 17 Apr 2013, 10:08
Welcome!
If you have any other questions don't hesitate to ask.
Postby velecin » 20 Apr 2013, 12:05
Hi!!!
I have installed it but I have a some problems!!!
I don´t know where I have to connect http://car-solutions.com/en/usb-touch-s ... roller.php
I connected the touch screen video interface for Range Rover Evoque but it does not work. Can you tell me how I have to connect it to my original touch screen work????? Any scheme or manual? I don´t need this http://car-solutions.com/en/accessories ... een-panels because my original scrren is touch (Range Rover Evoque touch screen 8´´)
I have three problems more:
- Where is the "MUTE" en my original touch screen??? I don´t know to connect it and while playing the GPS module (small speaker) also sounds original radio car speakers!!!! I don´t know how connect it!!!!
- I have a problem with keyboard. It can not be viewed on the screen completely, it is cut! I put a picture. I do not know how I can configure it! Also it always appears in the same place and not let me see the screen where all the folders
- When I put internet it doesn´t work!!!! It shows me the following message (look the photo). What happend????
velecin
Postby Chortenia » 22 Apr 2013, 12:56
Select USB Touch Eeti protocol in CS9200 settings (panel), it's located almost in the end of the list. Make calibration after restart.
Connect white wire on the power cable to Mute wire of your head unit.
You can move the keyboard.
The manufacturer does not install Internet Explorer on these navigation boxes. You can use any other browser, e.g. Opera. Rename Opera_Mini.exe into adzoommt-armv4i.exe
Postby velecin » 22 Apr 2013, 14:03
S
But I haven´t connected http://car-solutions.com/en/usb-touch-s ... roller.php because I don´t know where connect it. I have connected directly to the original touch screen to car video interface for Range Rover Evoque (http://car-solutions.com/es/car-video-i ... evoque.php) and car video interface for Range Rover Evoque connect directly to CS9200, I have not used the USB touch screen controller.
I have connected it this way: Original touch screen --------¬ Car Video Interface for Range Rover Evoque-----------¬ CS9200R. I haven´t used the USB Touch Screen Controller.
Please, can you send me any scheme or manual to connect it????? I think my connection is bad.
velecin
Postby Chortenia » 22 Apr 2013, 15:13
Please refer to the following manual. Look at the page 3 where touch cable goes from navigation. So here put USB touch screen controller instead of touch cable. The connector's step does not coincide with the socket on the video interface so you need to remake it by yourself.
Postby velecin » 22 Apr 2013, 15:49
Ok!!!
Thank you very much.
I will try it.
Kind regards
velecin
Postby velecin » 28 Apr 2013, 00:35
Hi!!!
I have connected the USB touch screen controller following the manual page 3 but the CS9200 does not recognize the USB touch screen controller.
What could have happened?
What would have to do now???
velecin
Postby velecin » 28 Apr 2013, 14:41
Could you send me more photos of the installation??
https://picasaweb.google.com/1090933727 ... 3000120274
I have problems with the USB touch screen controller and with the sound (original radio always sounds while the CS9200 with GPS function).
velecin
Postby Chortenia » 29 Apr 2013, 10:42
Update the firmware. Here is the manual
Postby velecin » 29 Apr 2013, 13:46
I have to put into SD: SD CARD 1 + FW_CS9200_v0.87_Car Solutions.Bin or only archives of SD CARD 1
I have copied all files (only files, no folder) from SD 1 folder to SD and I have made step 2 but it doesn't load.
velecin
Return to USB Touch Screen Controller USB-TC01
