Ael wrote:Hello, here is what happened.
1. I've copied the files from the archive from the first link on a blank SD card. Insert in the device and start it. Then it starts to flash the ROM but it stop on the 4th line "Program Done". I've wait for a more then 10 minutes and then I decide to insert the other card with the update.zip file. I shut down the device, take the card out and put the other one in and when I start it the resolution was messed up with the all other settings, so now I cant tell if I did it wright or not. I see something on the screen of the navi but dont know the flash was successful or not.
2. Then I decide to connect the box to external monitor through CVBS video port so I can fix the resolution. I've tried on 5 different TVs and Monitors and I cant see any video signal. I even ordered one Video to VGA converter so I can try on the computer screen but so far with no success.
So now I have one half flashed (maybe) android box witch I cant run on CVBS Monitor for some reason. At least is not Bootlooping now![]()
What is the next think we can do so I can get this think to work again ?
Ael wrote:Just tried with 4.3 and after that with 4.1. No picture at all on 2 TVs with different video cables. It updates for sure because the ZIP file is gone from the card right after I power up the device.
When I connect it with RGB adapter to the factory screen comes a picture but the resolution is wrong so I can not see what is on the screen.
So now I will have to contact the sales department for replacement/repair.
#PANEL EXT 800x480
"vs0=800,480,2944,72,95,26,7,2,12"
"ld=160"
"ec=T02:P67"
"acc=10"
#END
Ael wrote:Is it something special that I have to do when I connect CVBS monitor to the device? It's all about to plug the video cable and power up the device right?
With the wrong resolution on the navigation screen now I see one horizontal white stripe in the middle witch I assume at it is the calibration screen with the white cross in the middle. So basically the device is working just fine, that's why I'm wondering if I'm doing something wrong with connecting it to an external monitor?
Users browsing this forum: No registered users and 7 guests
