9320 with kenwood ddx8024bt
Postby oferelijah » 11 Jul 2014, 17:59
hi,
all working great but 3 problems.
1. panel set to kenwood, but what is my resulotion setting in my ddx8024 connectet wit RGB (not hdmi)?
2. what model to select with my ddx 8024 on the touch selctor?
3. i cant hear sound from the 9320 to my kenwood, i had 9100 and it was working perfect, i need to connect the mute wire of the 24pin cable in the 9320? to where in my kenwood ddx8024?
thank you very much.
ofer.
oferelijah
Car: Golf GTI
Re: 9320 with kenwood ddx8024bt
Postby Chortenia » 15 Jul 2014, 11:26
1. Resolution: 480х234, panel: Kenwood
2. Most likely it's DDX7039, but try other ones if this doesn't work
3. No, you don't have to connect the mute. The sound isn't played because of the wrongly selected protocol.
Postby oferelijah » 16 Jul 2014, 14:18
thank you.
i will try it later after work.
one more,
in the kenwood site it says that the ddx8024bt has 800/480
so whay to put 480х234? the 7039 has Resolution of 480х234
my has 800/400... its more like DDX8026, no?
ddx8024bt spec for kenwood site:
Video Specifications
Color System of External Video Input NTSC/PAL
External Video Input Level (RCA) 1 Vpp / 75 Ohm
External Audio Max. Input Level (RCA) 2 V / 25 kOhm
Analog RGB Input 0.7 Vpp / 75 Ohm
Video Output Level (RCA) 1 Vpp / 75 Ohm
Audio Output Level (RCA) 1.2 Vpp / 10 kOhm
Monitor Specifications
Screen size (Diagonal) 6.98 Inches Wide
Screen Size (WxH) 157.2 x 82.3mm
Display system Transparent TN LCD Panel
Drive system TFT Active Matrix System
Number of Pixels 1152000pixels (800(H) x 480(V) x RGB)
Effective pixels 99.99%
Pixel arrangement RGB Striped
Back lighting Cold Cathode Fluorescent Tube
DDX8026 spec from kenwood site:
Screen size (Diagonal) 6.95 Inches Wide
Screen Size (WxH) 156.6 x 81.6mm
Back lighting LED (Light Emitting Diode)
oferelijah
Car: Golf GTI
Postby Chortenia » 16 Jul 2014, 16:01
Number of Pixels 1152000pixels (800(H) x 480(V) x RGB) - it's a resolution of the display matrix, input RGB resolution is 480х234. Please, refer to the specifications of the OEM Kenwood navigation.
Postby oferelijah » 16 Jul 2014, 20:28
Thank you very much!
oferelijah
Car: Golf GTI
