Connect CS9320 to Video Interface of Range Rover Evoque 2013
Postby evoque2013 » 07 Feb 2015, 17:41
last week I got my Navigation Android Box CS9320 and my Video Interface for Range Rover, Land Rover and Jaguar.
Now i have a problem connecting the CS9320 to my video interface. The connection from vide interface to my OEM unit is clear but which cable do i have to connect to implement touch and video functions.
Can anybody help me? Detailed Diagram will be helpful
Thanks a lot
evoque2013
Car: Range Rover Evoque
Re: Connect CS9320 to Video Interface of Range Rover Evoque
Postby Chortenia » 12 Feb 2015, 18:52
Please, provide the link to the video interface you are talking about.
Postby evoque2013 » 13 Feb 2015, 19:30
evoque2013
Postby Chortenia » 16 Feb 2015, 18:46
To transfer video signal from 9320 use the following adapter:
For touch functions you need 4pin cable or connector like this one (if Android device)
Postby evoque2013 » 16 Feb 2015, 19:42
Thank you very much, i build all the staff already in my car (Range Rover Evoque 2013 incl. 8" Display)
Video and Touch is working also the CS9930 Android Box.
but I am not that happy with the Resolution of the screen.
They are little ticks on the screen. And I do not see everything on Display and yes i tried this 3Buttons and the back of the Video Interface.
I set the Dip Switches like this
1down,2-7up,8down
Can anybody tell me what are the best Settings, I do not need AV1 and AV2.
If somebody knows about the settings for the CS9320 the would be great either.
Thank you in advance.
evoque2013
Postby Chortenia » 17 Feb 2015, 11:29
The DIP switch 4 on the video interface should be in ON position. In the box settings (Settings-Display-Screen change-Advanced settings) set the following: resolution - 800x480, Panel- standard, Touch - 4pin (or which it was).
If the image is off-center, try to adjust it using OSD menu of the video interface and 9320 Settings-Screen fine tuninng.
Postby evoque2013 » 17 Feb 2015, 23:12
Resolution of Display is mich better now.
A little bit of fine tuning I still have to do.
Thanks for your help. Very good support!
evoque2013
