Is it possible for you to create a wp9320_update.zip file which will set the default video to;
Resolution : 480х234, Panel: 480х234-JVC , Touch :Kenwood DDX7039?
Why? Because on a new install or a hard reset I would not need to connect up a RCA monitor. This would also help if I was away from home and the system crashed or I needed to perform a hard reset.
