No picture!!
No picture!!
Postby euanT » 17 Mar 2015, 15:49
I have connected this unit into the Low End Interface, and the reverse camera picture is OK, but when I switch to the CS9320 all I get is a wavvy line picture, unreadable. The Nav(in) connector is via RGB + Sync, could it be the display resolution???? Help!!!
euanT
Car: Jaguar X type 2009
Re: No picture!!
Postby Chortenia » 17 Mar 2015, 18:38
Hi!
The resolution of 9320 is 800х480 by default, and Low End interface supports only 480х234. Connect 9320 via CVBS and adjust the right resolution in Settings-display-screen change-advanced settings
Re: No picture!!
Postby euanT » 17 Mar 2015, 19:51
As suggested, resolution wrong!! adjusted and all working great, Thanks!!
euanT
Users browsing this forum: Google [Bot] and 8 guests
