How to install update
Postby euanT » 31 Mar 2015, 19:02
Hi, I have downloded the update ZIP for this unit, how do I install it?? Do I remove the SD card and insert the file there?? and then re-insert SD card! What improvements are on the update?, and will I have to re-install my downloads??
Euan
euanT
Car: Jaguar X type 2009
Re: How to install update
Postby Chortenia » 02 Apr 2015, 11:08
For Android4.3 Standard Version Update all - https://www.odrive.com/s/49447935-b0c1- ... 7-5c52c763 (copy zip to SD card, insert it into 9320 and turn power on)
Please note that settings and installed apps will be deleted after that.
https://www.odrive.com/s/d4cee57e-652e- ... 3-5c52c799 Here is the firmware for micro controller - (Settings-Customization-advanced settings-7777-FW upgrade)
Mainly there were stability bugs fixes.
Postby DxL » 08 Apr 2015, 11:29
Chortenia wrote:Hi.
For Android4.1.1 Standard Version Update all - https://dl.dropboxusercontent.com/u/83435392/WP9320/JB41/Standard/UPDATE_ALL/wp9920_update.zip (copy zip to SD card, insert it into 9320 and turn power on)
The settings and your programs will be deleted after that.
Here is the firmware for micro controller- (Settings-Customization-advanced settings-7777-FW upgrade)
Firmware for micro controller does not work.... :(
DxL
Car: Hyundai i30
Postby Yuretz » 08 Apr 2015, 15:28
DxL wrote:
Chortenia wrote:Hi.
https://dl.dropboxusercontent.com/u/712 ... 052015.Bin
Postby jety » 12 Apr 2015, 13:55
Hi!
I have the 9320 device and I've installed the provided update.
Thank you very much.
But most of the setting are protected by the password :(
Would you tell me that password?
jety
Car: bmw 3 e90
Postby Chortenia » 14 Apr 2015, 10:43
Password is indicated in the manual.
It's 7777
Postby Giorzo » 09 Aug 2016, 01:31
What is the last update for Navigation system for Toyota Touch & Go, Panasonic, CS9320A?
Giorzo
Car: Toyota Verso 2013
Postby Giorzo » 09 Aug 2016, 09:49
Yuretz wrote:
Giorzo wrote:What is the last update for Navigation system for Toyota Touch & Go, Panasonic, CS9320A?
https://dl.dropboxusercontent.com/u/834 ... update.zip - Android 4.1.1
https://dl.dropboxusercontent.com/u/834 ... update.zip - Android 4.3
Thanks !!!
Giorzo
Postby Giorzo » 10 Aug 2016, 17:48
Yuretz wrote:
DxL wrote:
Chortenia wrote:Hi.
What is the micro controller?
Giorzo
Postby Yuretz » 15 Aug 2016, 09:38
