Garmin HUD
Posted: 31 Jan 2016, 10:21
I am trying to use the Garmin HUD together with CS9320:
https://buy.garmin.com/en-US/US/on-the- ... 34348.html
It is an additional display that projects navigation instructions on the windscreen, that is connected with an Android device using bluetooth. The Android device has to use Navigon software (by the way, very good navigation software for Europe).
I am able to pair the HUD with CS9320 using AnwSdkSample without any issues. Navigon installed correctly. When I try to connect the Navigon software to the HUD, it asks me if I want to enable bluetooth, because bluetooth is disabled. When I click Yes, I get a system message that an application wanted to enable bluetooth, if I want to allow it. I click Yes and then a system message appears Bluetooth is turning on... and this message is displayed for more than 10 minutes (I didn't wait longer).
Can you please explain, if the A&W bluetooth stack is capable of making the bluetooth device somehow available to an application (Navigon)? I'd there a manual fit the AnwSdkSample application?
Or maybe it would be sufficient to force Navigon or Android software to understand, that bluetooth is on, and then the Navigon application would be able to find the paired HUD device?
I am not using bluetooth for anything else (i.e. handsfree), therefore it might be an option to use another ROM with stock Android bluetooth stack, do you know if such ROM is be available?
Please help, it is an interesting combination that I would like to make work.
