by Sueco » 06 Dec 2017, 19:03
The composite video output signal appears to work, however I've checked the RGB wiring and appears to be properly connected, so at this point I don't know if the failure lays in the RGB source or the receiver, anyway I made the stupid mistake of messing with the video output format while trying to figure out what's happening, so now I'm trying to reset the unit's parameters using the wp9920_update.zip file, without luck until now, I'm going to try until I get back the video output in interlaced composite and then recheck the RGB signals with a 4 channels scope.
Thanks and BR
