by pandavi » 24 Jan 2012, 22:33
Thanks again.
1. I have already connected the 9100 to a monitor and power source, the rmote control does nothing! THIS IS an IR REMOTE CONTROL DEVICE - NOT RF! an rf remote does not have a red transparent window in the front, this one does, and as I said, I tried all remote buttons, nothig happens on the screen, the cursor does not even sow up, I have used a USB mouse to control the 9100 and it works, but not with the included RC. May be the persons who sent it to me made a mistake, this can happen, but CS would need to replace it for me.
2.Re.the Rear View Cam. Today my rear view cam is connected to the car reverse lamp, so when I shift gear to reverse it gets 12V and powers up.
My only Q. is and was, for rear view cam power -
Option A: Do I leave it as is, connected to the reverse lamp?
Option B: Connect the gray wire from the interface also, together with the power wire FROM the cam, to the same source of power - the car Reverse lamp,
Option C: Connect the power wire FROM THE CAM to the grey wire ONLY, so the cam gets it's power from this wire.
Power wire from the Cam means - The 12 power wire of the Cam itself.
Grey wire means - The grey wire from the interface power cable.
Reverse Lamp means - The car's white rear lamp which lights up when gear shifting to reverse.
What is "the plafond cable of backwards movement"?
3.To answer your question at the end of your reply, Yes, I have installed car Audio systems before, your system is not a standard Car Audio device like a branded car radio, there are many cables with many wires in it, the package does not include a manual nor instructions! normaly, with any car electronic Audio system there is a detailed manual and instructions, the manual I have downloaded from CS website does not describe the functionality of each cable / wire / connection and whith what to connect it in different cases, the only very clear ilustrated instructins are re. the CAN wires connections.
I would not like any one to damage the equipment nor my car! this is why I am asking these questions, to prevent it from happening regardless of who is doing the installation, myself or a workshop.
A clear and comprehensive user manual + instalation instructions + specs would have done the Job!, you need to invest in it, just like the documantation boxed with a laptop, a washing machine or a kenwood or Pioneer car A/V system!
How come there is NO PAPER or FILE together with the CS9100? Describing the menues, the screens, the options, the installation and the handling of the device, how and where to load a navigation program and have the shortcut start it? you get such instructions with a symple $50 GPS device. Not all users can find it out by themselves!
There are 12 connection sockets in the 9100 box, why should one make a guess what is each one and when to use it?
The use of the remote control, 16 buttons, how to use it? mine is an IR Remote c., how should I know the device is RF remote controlled?
Think about it.
