LCD92.INF
LCD92.INF
Postby snnar » 16 Aug 2012, 05:12
I have a CS9200RV I, change resolution did not work continue on the windows logo does not show the menu
reference to the instructions needed to file LCD92.INF
Can I get it
snnar
Car: toyota
Re: LCD92.INF
Postby Chortenia » 16 Aug 2012, 09:50
Here it is.
Re: LCD92.INF
Postby snnar » 17 Aug 2012, 02:00
Installed the file in the memory 2 GB Empty and Reboot more than five times Did not work
See the pictures
Note that the memory (SDMMC) in which only 3 Folder
1 - backup
2 - Navi
3 - SMS1
And file device.nng
I can browse files in the device Where file run the main menu
Please help
Can you provide me installation guide Toyota Land Cruiser before 2005 CS9200RV
snnar
Car: toyota
Re: LCD92.INF
Postby Chortenia » 17 Aug 2012, 09:36
Our technical specialists need to know the number of your invoice.
Re: LCD92.INF
Postby snnar » 18 Aug 2012, 04:22
hi
Not send an invoice with the shipment
Order # 2510773
snnar
Car: toyota
Re: LCD92.INF
Postby Chortenia » 20 Aug 2012, 10:56
You need to reflash firmware of the device. Download firmware and follow the instructions below.
******************** Procedure of OS + APP update ********************
1. Copy the content of "SD Card 1" folder into memory card root (memory card up to 2 GB!!!).
2. Insert the memory card into navigation box and apply power.
3. Wait until the procedure finishes and "PLEASE REMOVE SD CARD" message appears.
4. Remove memory card from navigation box and disconnect power.
5. Delete previous files from the memory card and copy "SD Card 2" folder content to memory card .
6. Insert the memory card into navigation box and apply power.
7. Wait until the procedure finishes and "PLEASE REMOVE SD CARD" message appears.
8. Remove memory card from navigation box and disconnect power.
9. Update procedure is finished. Apply power, wait until settings come into action and main menu of navigation box appears.
10. Enter System, click Update firmware and select file "FW_CS9200_v0.73_Car Solutions.Bin". Count till 100 and reset the device.
11. Select corresponding protocol, screen resolution in Resolution tab. Reset the device.
Please, be aware that Car Solutions is not liable for device incorrect operation in case of unauthorised OS upgrade.
Re: LCD92.INF
Postby snnar » 29 Sep 2012, 09:41
I already Arabization of menu cs9100 into Arabic
How can Arabization of menus cs9200 to arabic lang
Garmin navigation program does not work with cs9200 I experience more than one version
snnar
Car: toyota
Re: LCD92.INF
Postby Chortenia » 01 Oct 2012, 12:36
We can add Arabian language to our menu. If our agree with our menu (see the screenshots below), please, fill in this Excel file and send it to mail support@car-solutions.com. Our menu will have more functions than the original one and will be multilingual.
You will find more screenshots in the attachment.
Menu arabization will take approximately on week. we will also adjust Garmin for CS9200.
Re: LCD92.INF
Postby snnar » 04 Oct 2012, 00:25
hi
translated excel file and sent to email technical support
snnar
Car: toyota
Re: LCD92.INF
Postby Chortenia » 04 Oct 2012, 12:04
We received your letter, thank you!
We started working on the issue.
Re: LCD92.INF
Postby snnar » 09 Oct 2012, 00:40
Is translation has been completed
How to Make Internet browser Opera is the default browser
I hope you give me Connect settings for modem Huawei Mobile Edition
Contact number * 99 #
Access Point
1 - jawalnet.com.sa
2-web2
3-zain
snnar
Car: toyota
Re: LCD92.INF
Postby Chortenia » 10 Oct 2012, 09:51
We faced some difficulties in Arabian language support in wince. However, we expect that till the end of the week we will solve these problems and send the menu to you.
As far as operator settings are concerned, you can do it yourself following our manual or we can send connection setting wizard already with your operator together with the menu.
P.S. Opera cannot be made default browser.
Re: LCD92.INF
Postby snnar » 10 Oct 2012, 11:26
Thanks for the reply
I have order 5 cs9200RV already
I want installed Arabic on these devices before sending
translation see attached picture as an example
snnar
Car: toyota
Re: LCD92.INF
Postby Chortenia » 11 Oct 2012, 17:09
Please, take a look on the following screenshot. Tel us whether everything is correct.
We apologize in advance for any possible mistakes (we do not know Arabian)
Re: LCD92.INF
Postby snnar » 15 Oct 2012, 23:37
Translation correct
And I tangled characters
Example:
not Correct : ا ل ر ئ ي س ي ة
Correct: الرئيسية
Only tools icon is correct in the image
I think that Windows CE does not support Arabic language in full
You can write on the icon using Photoshop
Send file icon and I'm on a writing in Arabic and bring it back to you
This file cs9100 I Translat icons
Menu.rar
(729.49 KiB) Downloaded 207826 times
snnar
Car: toyota
