1. Is Audio L & R the same as the SPK connection on the rear of the box?
2. Does the "IR DATA" connect to the TSC-206IM? and if not what is it used for?
3.Does VCC connect to ACC or BAT?
1. So 12v on "REVERSE" enables Video 2
2. So 12v on "VIDEO SW" enables Video 1
3. So "TOUCH RX" connects to the TSC-206IM pin J3 Navi RX, but,
Where is the "Touch TX" to connect to the TSC-206IM pin J4?
4. Is "12V out" switched on/off by some function?
5. What does "PIP in" in do?
6. What does "AGND" do?
