Connecting CS9200RV to Bluetooth
Postby 34by151 » 04 Oct 2012, 12:11
I Have the 9200RV (Product Code 835756)
http://car-solutions.com/en/cs9200rv-na ... nitors.php
Also the Bluetooth Cable for CS9200/CS9200RV (Product Code 834759)
http://car-solutions.com/en/bluetooth-c ... on-box.php
How do these connect as there is no instructions
From what I can work out
The PS2 type plug connects to the CS9200RV Uhart socket
The Black 3.5in socket (marked Mic) connects to the included microphone
What do the remaining plugs connect to?
These are
Red RCA (Audio L)
White RCA (Audio R)
Green 3.5in socket (Audio Out)
34by151
Car: Jaguar XJR
Re: Connecting CS9200RV to Bluetooth
Postby Chortenia » 04 Oct 2012, 13:37
Please, refer to the following scheme:
Postby 34by151 » 04 Oct 2012, 13:55
Thanks but the CS9200RV does not have the same connections on the back as the RV9200 that is in your picture
The RV9200RV has (from left to right)
DC In, Data, Vout, Mic, GPS Ant, Spk, RGB
The RV9200RV does not have the AR and AL rca as in your picture
34by151
Car: Jaguar XJR
Postby Chortenia » 04 Oct 2012, 14:34
Please, specify the length of your cable (0.5m or 1m) and how many wires it has (5 or 8).
Postby 34by151 » 04 Oct 2012, 14:49
The Bluetooth Cable I have is
(Product Code 834759) http://car-solutions.com/en/bluetooth-c ... on-box.php
It is aprox 1m long
The uhart plug has 6 pins
There are 3 cables cumming from the uhart plug (Mic, Audio Out, and the 3rd splits into Audio L and & at the end)
It is exactly the cable in the link above
34by151
Car: Jaguar XJR
Postby Chortenia » 04 Oct 2012, 14:58
Judging on another topic your RGB cable consists of left (orange), right (brown) and ground (black) wires. Join left and right with inner conductors of RCA cables and ground with the cable braiding.
Postby 34by151 » 04 Oct 2012, 15:16
I don't understand
Ar you saying to connect the bluetooth cable Audio L, Audio Right to the RGB cable left (orange), right (brown) and ground (black) wires?
Do I then used the audio out on the bluetooth cable for all the audio out from the RV?
Ie is that then the connection to my amp?
34by151
Car: Jaguar XJR
Postby Chortenia » 04 Oct 2012, 15:35
Yes, you're right!
Audio signal is taken from audio out of the bluetooth module. It can be used for amplifier connection.
Postby 34by151 » 04 Oct 2012, 15:39
Ok, So without the bluetooth, the RV audio aut to the amp is via the RGB cable
With the bluetooth it runs through the blutetooth cable
34by151
Car: Jaguar XJR
Postby Chortenia » 04 Oct 2012, 16:42
Yes, you are right!
Return to Additional Equipment for CS9100/CS9200 Navi Boxes
