Manuals and Firmwares
Universal touch screen controller for touch screen control of additionally connected devices, including navigation box, on OEM touch screen monitor or additionally installed touch screen panel.
Moderators: Germes, hslava
Postby Chortenia » 15 Nov 2012, 16:03
In this topic we will inform you on new firmwares, updates and manuals for multifunctional universal touch screen controller TSC-206IM.
Re: Manuals and Firmwares
Postby hslava » 15 Nov 2012, 17:37
Hi all. I am designer of the TSC206IM device.
Now i have uploaded a new release of software. All you need is in the one pack TSC206 updates.zip. The stepwise manual too.Good luck, And two important notes:
first. To update firmware and set working parameters of TSC206IM you need use my programming adaptor. To do this your PC must support USB1.1. If not, updating and parameters setting will be unavailable. Now i amsolving this problem by making new device that will support USB2.0 protocol.
second. Never use ungrounded AC/DC converters to supply power to controller. Otherwise this can damage device when you touch any conponent by your finger, because of puls of volage will be generated. Your finger is grounded.
Thanks. Good luck.
PS. I attached an instruction manual too.
TSC-206IM_manual.pdf
(494 KiB) Downloaded 3021 times
TSC206 updates.zip
(1.49 MiB) Downloaded 2367 times
hslava
Car: lexus
Return to TSC-206IM Controller
